1 - 14 of 14 Posts
Hi guys, I've had my srt4 for about 6 months now, and I decided to replace the clutch, because it was worn down. When I did, and I put it back together there is now a rattling noise coming from the clutch area. Ive replaced the clutch, TOB, clutch fork pivot ball, and the clips. It only makes the noise when I press the clutch pedal and when I release the pedal it stops. Any ideas on what it could be?
What brand parts did you install?
does it only happen when the clutch is pressed in all the way? can you feel it in the pedal?
I got all oem parts from modern performance. And it happens like as soon as you put pressure on the pedal.
i'd suggest removing the inspection cover (black cover) by the slave cylinder and looking in. Make sure the TOB is riding on the fork correctly. Hopefully you replaced the fork also while you were in there.
if you can get a video for us to see, that may help.
So I found out the car had a spec clutch in it and you are supposed to replace the factory flex plate. Do you think that could be the problem since I'm trying to put a oem clutch back in it? Also the fork got replaced also.
to the best of my knowledge the flex plate never has to be replaced unless its damaged somehow or you're replacing it with a non-modular style clutch/flywheel.
Discussion Starter · #8 ·
I was reading specs website and thats what it said. I didn't think you had to either but thats what their website said.
That doesn’t make sense as the only thing the flex plate does is act as a mounting point for the clutch and give the starter something to spin...
2005 srt4
so i broke the TOB clips on mine and wrote modern performance about it they told me that it will just make a rattling sound when you press and/or release the clutch. more than likely during install of the TOB you either did like i did and broke the little clips on it or just did not place them in place.
many of the aftermarket TOB forks require those tabs be broken off.
2005 srt4
Cool, I didn't know that, might explain why they broke while being put on. I have a little chatter when off the clutch in neutral but still works the way it should.
Thanks for all the input.
1 - 14 of 14 Posts
