1 - 9 of 9 Posts
i cant get my line to go back over {reinstall}on the quick release hydraulic line. is there a certain way to do it?
If you are talking about the clutch line, I had the same problem. I guessing you just put a new clutch in your car. I had to remove the clutch slave cylinder , attach the hydraulic line, then re-attace the slave back in the trans.
did you get this done without having to lower the tranny?
yep, there is a square black acess cover on the front of the trans where the clutch line goes. There is a clip you take out and then the slave twists out.
is it the plastic clip half inside and half out, when you remove the black cover?
yeah I think thats the one.. i'll see if i can find a picture in my service manual
Discussion Starter #7
hey thanks brotha, but i got it after you told me that. you were a great help
How did you remove the hydraulic line in the first place? Special tool or something else?
Got it! 18mm open end wrench pressed toward front of vehicle. Used spark plug pliers (rubber tips) to grab the master side and my hand for the slave side.
1 - 9 of 9 Posts
