Over 500? no.
You going to polishup the letterings?
Well if your valve cover get over 500 degrees say good by to your motor.:grimrippeeviilboy said:So my spark plug tunnel o-rings were leaking.. and I decided to buy a new valve cover gasket... got a new valve cover and gasket.
This is how it looked:
And after a few hours of dorking around with it... and painting... this is how it looks now...
Quick question, you guys think our valve covers get over 500F?
AdvanSRT-4 said:Over 500? no.
mahkis said:looks good, wrinkle red? how many coats did you use? did you have a problem with the rattle can nozzle cloggin up?
i used wrinkle red on a honda build i did recently, and i had a hell of a time with the can nozzle. it would clog after every coat, and eventually, it clogged completely.
tinctorus said:why not just stick it in the oven to speed up the drying time???
touche(sp?) salesmantinctorus said:why not just stick it in the oven to speed up the drying time???
yea, i followed the directions, maybe i just bought a can that had been sitting on the shelf for a while.eviilboy said:mahkis said:looks good, wrinkle red? how many coats did you use? did you have a problem with the rattle can nozzle cloggin up?
I used an entire can, the directions said heavy coats.
Even with waiting about 7-10 minutes between coats... I never had a problem with the nozzle clogging.
Though I do think I might have gone too heavy, and might need to strip it.. and repaint it with lighter coats.
I'll know in a couple days when it's done "curing"...![]()
mahkis said:yea, i followed the directions, maybe i just bought a can that had been sitting on the shelf for a while.eviilboy said:mahkis said:looks good, wrinkle red? how many coats did you use? did you have a problem with the rattle can nozzle cloggin up?
i think you used the right amount. if you use lighter/less coats the color is not the same. the car that i did came out looking pinkish because i could not apply enough coats. at any rate, wait until it dries completely before you decide whether to strip and redo it or not.
AdvanSRT-4 said:I also did mine in a wrinkle finish, black. I didn't want to put it in the oven, so I put it out in the sun for the most part of the day, it worked.![]()
OH5SRT4 said:What did you use to spray that and where'd you pick it up? I need to add some zip to my engine bay.
