Ring gear? You sure the input shaft doesn't need to be rotated a bit to seat into the clutch?
so i might have to reinstall the tranny mount and top motor bolts to hold it and take some pressure off of the speed sensor bolt to try and get it out.
Oh. Yea, you didn't remove the top motor mount bolt..I was referring to the bolt that actually holds the upper motor mount in, not the bolts that hold the tranny housing to the motor. I've always had good luck with PB blaster and a breaker bar.Yeah the two bolts ontop of the tranny case that go to the motor.
Mine just took a lot of "finesse"..it was a pain to line up and get it in there right, for sure. I found it easiest to put the top two tranny bolts in, and use those as "guides"..once those were lined up the rest of it kind of clicked in and I was good to go. Keep at it..it'll go!
I mean the two that mount from the motor to the bellhousing (I think). I know where it's at, but it's been a while since I did that. I'll have to look at a picture so I can point them out. One is near where the shift cables mount to the tranny.So by tranny bolts you do mean the ones on the tranny mount, chassis side, right? Thanks in advance!
Im gonna suggest checking ur mounts with a torque wrench. double check all u bellhouseing bolts are tight.alright... so a few weeks ago i dropped my tranny to swap my 3/4 shift fork and everything is good to go... except a few things... whenever i accelerate i can feel the engine and what not kind lift as if the mounts are tight... but i double checked the mounts and they are snug tight. i also have my ABS light on... and i can't seem to figure out why... anyone have any idea?
Check your intermediate shaft bearing on the passenger side. i had mine go bad and felt like hell pulling out.
for abs light.. doublecheck the sensors near the brakes. make sure u didnt accidently break the line or get stuff in the sensor area. then reset battery
could be axle, rack and pinion, not having a properly torqued axle nut or any loose hardware. go back under the car and verify torque on the bolts.Alright... So check this out... It's been about a month/month and a half and everything was good up until a couple days ago. Whenever I turn right.., I hear and unbearable clicking sound comin from what sounds like my axel. I'm on my way home right now to check it out. But anyone know of this problem? And also my mounts still feel loose... Even after checking all the bolts with the torque wrench. Any ideas?
