1 - 13 of 13 Posts
· Banned
eh, im workin on my car and im trying to take off my headlight (as you read this) so i can replace my turn signals. how the hell do i take it out? i unscrewed the 2 screws that hold it in place the 3 top bumper screws for flexability and 1 on the quarter panel and still cant get it off...wth? any helpful suggestions?
~mike
· Registered
I had the same post a few days ago when I was trying to take mine off. There isn't really a trick. I just ended up pulling/pushing and bending the top of the fascia until it came out. They didn't come out like the owners manual says, which is pull the right side out first. I believe that I actually pushed the outside of the light into the fender and then lifted the inside section of the light up while bending out the fascia a bit.
· Banned
Slvrstreak said:
unscrew the 1st screw on each side to the top bumper. so you can lift up on the bumper to wedge the headlight out. try that...
i took off all 3 on top, still no help. im afraid to push/bend the fasia like the otehr suggested because my luck ill f*** it up. im aggravated as hell...lol
· Registered
you just have to wiggle that shit around till you find that sweet spot to get it off. i've had my headlights off many times. it just takes a lot of patience like everything else on our cars u know? good luck on it bro!
· Registered
I know what you mean. I started to take it off and then got mad at it an stopped. I thought I was going to brake something too. It did seem more difficult than it should have been. Like I said I lifted the inside bracket of the light off first. I did this by lifting it straight up. And it helped to first push the outside part of the light into the fender.
· Banned
thanks for the info guys and the fast responses. i got the passenger side off by pushing 1 side in and pullin the other side out. now im tryin to take the 'plug' off. thanks
· Registered
i just replaced my turn signals, and headlights w/ Silverstar lights and i didnt remove anything, ubt the airbox for the driver side headlight, but other than that i just reached in the holes and twisted the bulbs out and replaced them the same way... now if i could just find the damn foglight bulbs so it doesnt look retarded w/ 2 diff. color bulbs :flame:
· Banned
Discussion Starter · #12 ·
sarrett said:
read the maneul..
:knockhead doh! i knew i shuda looked there...
on a serious note, once i found out a way, i replaced both w/in 3 min. jus took patience.
· Registered
Just did this friday night, and have done it to my old SRT before too. Just unbolt the 3 bolts on the front facia, and then just [email protected]#&ing pull those things out. Try to bend the facia the least amount possible, but i didn't have a problem. I didn't want to force it out eather, but i got so mad i did finally and it worked. That plastic can take a lot so don't be afraid. If you think getting it off it hard, just wait till you put it back on. Need even more bending (or so it seems) don't be afraid though, that is the best piece of advise i can give you.
1 - 13 of 13 Posts
