1 - 20 of 105 Posts
Moderators feel free to move this to the how-to section when you see fit.
Ingredients
"Great Stuff, big gap filler"-5$
expired credit card-free
Led light board from srt4store-45$
optional...
acetone (if you make a mess)
step 1
put taillights in the oven (rest them on a towel so they dont melt) at 200 degrees for 5 mins at a time until they are soft enough to pry apart with a butter knife...
VERY IMPORTANT!!!!
wrap the wires around the screw at the back of the taillight so that the led board stays in place while you apply the great stuff. Or have your friend hold the other side while you spray it.
Discussion Starter · #10 ·
wait approx 3-4 hours for it to cure...
use the acetone on the stubborn foam that wont come off, acetone dissolves it with the quickness!
put the taillights back into the oven (AFTER the foam has cured for at least 8 hours) at 200 degrees and press them back together (you could also use a hairdryer for this step)
BTR said:
Stage2BlackSRT4 said:
Good write UP! thank you, I'm going to have to do this.. Are they brighter then stock?
I'll post a comparison later :clap:
Sweet, thanks for taking the time to do the write up
wow, here i thought someone was tryin their own thing......then here i realise whos doing it...and what they're using...haha
good job man! more than i did, thats for sure, but mad props none the less! i just used JB Weld to hold mine in place :)
i'm actually going to release these again, this time i'm thinkin of 5mm wide angle red led's, instead of the 3mm narrow angle led's... Sure they wont be as bright but the led's have a 120degree viewing angle, so youll CLEARLY see the tails from any angle.
I'll probably do both, let people choose, but so far i've compared the 5mm wide and 3mm narrow side by side, and so far, i'm really liking the way the 5mm looks compared to the 3mm :)
scrub: ill let you know soon as i have more ready to ship. my factories are both closed till the end of the money for their spring festival.....
Discussion Starter · #20 ·
WTF?
all that work I did and NOW you release the wide angle ones?!?!?!? :grimrippe
1 - 20 of 105 Posts
