*sigh*
[vu]juan said:*sigh*
*holds back* If you're running stock, meaning, no upgraded Wastegate, don't even bother with a boost controller.elcangri1 said:With a boost controller how high can I boost the turbo and still running safe.
Slow_spool said:how much boost can a ported compressor and manifold handle?
That is such a NOOB thing to say!! dont use duct tape it only last one run! you gotta use that new heat resistant scotch tape!! Duh!$RT4 said:just duct tape the WG and turn up the boost to 30 psi :thumbsup:
blackhawk said:That is such a NOOB thing to say!! dont use duct tape it only last one run! you gotta use that new heat resistant scotch tape!! Duh!$RT4 said:just duct tape the WG and turn up the boost to 30 psi :thumbsup:
you are not holding 20.srtkidd420 said:i got 22 set on MBC holdin 20 with s2 WG all the way tight no problems.
