How fast have you guys gone in fourth gear, just for a reference point, i have heard it tops at 129- 130, but when i tried it i was surprised. so what have you all been getting.
126 is the speed....but depending on wheel diameter tire pressure and all that other happy jazz it can vary within a 5 MPH give or take kinda deal.....But i believe 126 is the max in 4th gear.....Speedo's start to lose accuracy real fast when you get up to those speeds also.....
ok im not sure how accurate my speedo is, but it read 140, i was thinking i was in 5th, cuz i forgot, then it hit the rev limiter and i looked down and still had another gear, i doubt my speedo is off by 15
wow no way could you hit 140 in fourth....what was your tire pressure at what kinda wheels are you running (stock?)??? these are just some questions.....cuz i don't think it is possible to run the car up to 140 in fourth gear that would have to be close to or over 7,000 RPM and that and our cars just don't mix.....
i dont know i just put it in fourth and put it down at 90, by the time i got there i forgot i was in fourth, i look up and it was 135 then right at 140 it cut out, for sure in fourth, dont know the rpms, my car is stock with 41 lbs in the tires
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
