GReddy PRofect-eo1
I just got mine in today and I must say its a very nice unit with a large amount of features. The boost control setup on it is excellent. YOu can control your boost as fast or slow as you want. You can also cause it to raise the boost the higher you go in RPM. The display can be set to read PSI, Bar or KPa
The solenoid is very very small in size which is great being that there is not much space in teh engine bay. You can also data log your RPM and boost as well as some other stuff.
IM yet to install it but I received it today and will be doing a full install and documentation of it so it will be easier for those of you who purchase it from me.
This unit is costly and I dont recommend you get it UNLESS you plan on getting the Emanage computer later on.
e-Manage portion
Its about $300 or so which is alot cheaper than the apexi AFC. With th e-manage, you can piggy back it to your stock computer to controll your injectors . You can also adjust your ignition timing as well. And its also great to know that you can bypass the fuel cut with it! So you can raise your boost to 17psi and not worry about a CEL or a fuel cut.
It can also run additional injectors or larger injectors which is great !
IM still in the process of reading the book so im learning as I go.
e-Manage portion
