how do i fix....P0301
1 reading
706 views 9 replies 4 participants last post by  NaZkaR
#1 ·
the Check engine light came on and it throws P0301
which is "p0301- cylinder #1 misfire'
how do i fix that...or what do i have to do in order to get the check engine light gone,....
please help me out guys...
#2 ·
Check spark plugs, wires. Could also be the coil pack. If those check out fine, could be a clogged injector...switch the injector with a different cylinder and see if the misfire follows to that cylinder.
As for getting rid of the CEL....unhook battery terminal for about 10mins, or remove the ASD relay.
#8 ·
Hmu if you need help. I can find out what's causing it. Don't take it to some crrappy shop that doesn't know our cars..
