I had my stage 2 installed at the dealer about 2 months ago, today for the first time since it was finally nice out i bought 5 gallons of racegas and mixed it in with 3.5 gallons of 93. Now i pushed the HOM button and the led didn't light up. The car really didn't seem to pull much harder and I'm wondering is is possible that HOM is hooked up, or is just the led not hooked up, any feedback would help.
thanks
chris
You have to hold the button until the led lights up. You will notice a difference! The led should be lightly lit all the time if installed correctly. It is very bright once engaged. Even if the led is not installed right I think if you start your car and then hold the hom button for about two seconds it should be enabled.
As stated above. If it isn't lighting up dimly at start-up all the time, the leads running to the back of the LED are switched.
thanks
chris
you should just be able to push it and the RED LED should come on. You will notice a big difference in performance with it engaged, if you dont, take it back and have them check through their wiring job. You paid a good amount to have them install it, so it should be PERFECT........
i tried my HOM last week with 100 octane sunoco race gas and some 104+ the LED lit right up and it felt a little more powerful but it didn't feel like an extra 15 or 20.
smelled good though coming out the back!
same thing happened to me. the two wires on the back of the red LED just need to be reversed. takes 3.5 seconds.
