1 - 7 of 7 Posts
Has anyone installed a resistor in the HOM LED so that it doesn't dimly glow all the time? If so, what ohm value? Thanks.
not sure that will work.. I tested the voltage with hom off and it like 6-7 volts dc and 12-14 vdc when on. I did get it to be a lot dimmer when I replaced the led with one from radio shack with a built in resistor. Before hand the red led was blinding me at night when on.
jasonsrt4 said:
mine is not dimly lit up?
It's supposed to be at all times when the car is running.
i took the resister out of mine and now it only lights up when i turn on hom. I moved my leds into the heater vents so you dont see them till they are on and then they light up the vents
Im very supprised you have not blown your led.
Discussion Starter #7 (Edited)
I know I read on here a while back that someone had done it, and that it had worked. I wish I could remember the guys' name, he's posted a lot in the audio section, I think.
1 - 7 of 7 Posts
