wha??? ems?
What about the other gears?04badsrt4 said:when i get at 7000 rpm going to 2nd gear will not shift. If you shift at lower rpm it will go no promblem.What might be the promblem
Does it really matter that much? Im sure it aint stock. Its either ems or a flash or really aggresive driving :jester:hyypro said:What kind of ECU do you have in your car that you can get to 7000 rpm. Stage 0 is 6200, stage 2 is 6500.
Wut this person said. Start at your pedal adjustment first.hyypro said:Have you adjusted your clutch pedal closer to the floor board. If you have, your clutch does not release as far and the synch gears may not be able to mesh at the higher rpms.
I have already adjusted the clutch. I have the act 6 puck clutchstxsrt said:Wut this person said. Start at your pedal adjustment first.hyypro said:Have you adjusted your clutch pedal closer to the floor board. If you have, your clutch does not release as far and the synch gears may not be able to mesh at the higher rpms.
