Ever since installing Stage 2, I've noticed when accelerating, doesn't matter what gear, but if I give about half throttle or less, the car hesitates for about a second then goes fine.
I've also had trouble trying for 20 lbs of boost. I have the AGP wastegate, and I went to the track a couple months ago and tried jumping up from 18 to 20 lbs and I lost about 4 mph in the 1/4.
Anybody having similar problems? Or had something similar to this? I'm pretty sure I'm not leaking boost, I mean I can hit 18psi.
Any help is NEEDED!!! Thanks.
Bump. I'm now having this problem, but not in all gears. I just installed s2 the other day. nice pull off the line, wot to second - no problem until quickly into 3rd gear (hesitation around 4k-4.8k) then pulls hard again. I regapped plugs to .038 and no change. Could it be my dasmopar mapclamp? my a/f is a bit rich 10.8 - 11.2 4th gear wot.
any suggestions?
Try changing spark plugs and since your running higher boost you would want to short the gap in the plugs. Stock is usually around .052. Try .034. BIG difference. I had the same problem
