· Registered
vacuum lines help plz
Ok, i did the vacuum lines like the PSIfi told us, the only thing i didnt do it was the BOV line(still stock) I have the mopar BOV, But now i cant pass 10psi of boost. What did i miss? Should a tune better the s2 wg and turbo xs MBC? There is any other vacuum lines that i should take care of it?
Any help is apreciated.
· Registered
see now, the pcm is what gave that "leak" at the solenoid were it delays the signal to the wga.. now that your pcm is out of the loop, you have to turn up your boost controller to your desired boost level..
