I am not a grade A mechanic, but I can do basic shit. The install of the STS and bushings went very smoothly, the only thing that I could not figure out to save my life was why I received 4 bushings. I only used 2 out of the 4. Did i miss up, or did I just receive extra. It only took me 30 minutes to install, so it wont be that much of a p.i.t.a. to take apart again, I just want to have the job done right. So are you supposed to use all 4 bushings?
BTW.. What a difference, definitely a mod worth doing!
the other two on the trans side of the shifter remove the battery and battery box and you can see where the two other busshings go
Is it Necessary that I put the other two in? Will I hurt something if I don't do it right away?
You dont have to install them, you wont notice a big difference but since you have them you might as well.
You dont have to take the battery tray out just the Air Box. Should take you 5 mins-10 minutes for airbox
Damn you guys are fast. Thanks for all the help! :)
