1 - 9 of 9 Posts
I took the srt4 to work the other day and on the way back i decided to give it some gas, now it misfires. Car threw up code p0302 so i checked the spark plugs and changed the wires. The car kinda sounds like a subaru. If any one has any ideas please help!
Replace them with a new set with proper gap. Reset PCM. If that doesn't help, then you can try something else.
Discussion Starter #7
Haha it sounds good but not healthy, what are the chances that the fuel injector is bad?
If you think it's an injector, swap #2 with another and see if it changes your misfire code to a different cylinder.
Chances are it's a plug or coil pack since you already did the wires.
1 - 9 of 9 Posts
