· Registered
okay, before i installed the IP2 36-way fully adjustable coilovers, i already had the psi-fi dogbone motormounts(upper and lower), and had NO WHEELHOP! i installed the IP2's, got the car aligned, and have almost 4,000 miles on the new coilovers :clap: HOWEVER, my question is this....why do i get wheelhop again since the coilover install? i was told it was because the spring rates i have set on the coilovers may be too stiff? I have all 4 corners of the car setup only ONE click TOWARDS the soft setting OFF of full hard, so to put it in easy words...i had all 4 corners set as stiff as can be, then turned each only one click off of full stiff. What is the best way of dampening to NOT have wheelhop yet handle the best w/these coilovers? any help would be appreciated! thanks!
- Chris:cool:
· Registered
i was told to just snug the spring the the ipp parch.. your saying the perload spring.. is that correct.. how much do you perload it.and how do you know what spring tension you r at..
· Registered
just put them on car the way i did for now.. i will try and find out more about what psi-fi is saying to do..
go here a see this right up on ipp in the brake/performance section..
http://www.hybridsrt.com/index.php?
