after i connected all the wiring for stage 2 toys, my 100 octane light comes on whenever the car starts. it only comes on dimmed. nothing happens w/ the led when i push the switch. Don't know whats wrong. someone help.
yea the blue one works fine..Dale Seeley said:Having the red LED lit a little is normal. Not having it get bright when you push the red button is not normal...
When you push the Blue button, does the Blue LED illuminate?
Take the time to inspect every connection made during the install. If you are decent with a wiring diagram, the one in the install manual will help you narrow down which connections may be giving you trouble.
Be sure that the pins installed in the PCM connectors are fully inserted and look like the original pins that were there before the install.
Be sure that the couple connections that required soldering were soldered and not twist/taped, or scotch-lok'ed or any other quick-n-easy method.
It should be a simple fix once the problem is found.
Dale
moltenice said:rather then making a new thread, i'll just bump this one back up..........
So here are my questions, please bear with me.
I was under the assumption that if you did NOT have 100 octane in and you pushed that button, the led would flash at you telling you your a retard; until you pushed it again turning it off. Am i wrong on this? cause mine will stay lit up at idle if i push that button.
Second, is it suppose to sound different if you push that button on 91 octane? i mean do you hear somthing change over as your car attempts to advance timing, or is it un-noticeable...
thanks guys for humoring me.........
Right answer for this questionglhs837 said:it's fine, we all have that, it shoud work, search "racegas and led and lit"
