broken mounts?
Also, does it shake on WOT accl only?
I've seen bad plug wires cause horrible shake and vibrations above 8PSi
thats interesting... it doesnt have to be WOT to get the shaking, but always in boost.. I'll drive it a bit tomorrow and try to see if i can pinpoint a specific starting point as far as psi or rpm'scali said:broken mounts?
Yes but this would also cause a good amount of hesitation... is power delivery ok smoger?cali said:broken mounts?
yeah,.. the only thing wrong with power delivery is my brain wont let my foot stay planted once i feel the shaking :lol:fusion said:Yes but this would also cause a good amount of hesitation... is power delivery ok smoger?cali said:broken mounts?
as in motor mounts? they're fine(at least the top and bottom one are, not positive about the third one)ENapa said:You dont need a new intermediate shaft for the 04 axles. You should have replaced both of them in the first place. I would check for broken mounts.
Check axle. I had the same problem. Turned out being pass. axle and also, have you had a flat recently? I had a flat and put in can of Fix-a-Flat and it turned out that it didn't spread correctly, thus throwing off the balance of the front of the car, making the car shake.:readclosesmoger said:bump to find out if i can check to see if my axle is bad without removing it from the car...
Is there a way to check the axle without pulling it off the car?Jagok1 said:Check axle. I had the same problem. Turned out being pass. axle and also, have you had a flat recently? I had a flat and put in can of Fix-a-Flat and it turned out that it didn't spread correctly, thus throwing off the balance of the front of the car, making the car shake.:readclosesmoger said:bump to find out if i can check to see if my axle is bad without removing it from the car...
Yea, it was a emergency, but I had used it before with no problems:jester: Just get under the car, grab the axle, and check it for play.smoger said:Is there a way to check the axle without pulling it off the car?Jagok1 said:Check axle. I had the same problem. Turned out being pass. axle and also, have you had a flat recently? I had a flat and put in can of Fix-a-Flat and it turned out that it didn't spread correctly, thus throwing off the balance of the front of the car, making the car shake.:readclosesmoger said:bump to find out if i can check to see if my axle is bad without removing it from the car...
No flats, but for future reference,.. i think fix a flat is only an emergency fix and i think even the can tells you to replace the tire ASAP![]()
Yea, jack it up:hi:smoger said:can i jack it up to check it? or does it need to be on the ground?
THANKS!
