how in the hell do I remove this damn sensor ? I'm trying to do the TPS re-wire and can't get this off.
TPS is throttle position sensor....
what happens is the wire inside the insulation goes bad, it falls apart inside of the insulation and if the wires get moved around they can go completely bad or sometimes they can show signs only every now and then. Basicly what will happen is the car will idle high and have a little bit of a studder.
theres a write up in the how to section
