1 - 9 of 9 Posts
· Registered
The aim is 450whp to 500whp car.
The mod list i had it my mind:
ECU: Stage 1 with S-AFC (Since it has a more friendly map for high boost 20-24psi) or standalone system (didnt decide which one until i see reviews on them).
Fuel System: Larger intank Fuel pump and 750cc injectors (Not sure if that is enough, but i know S-AFC cant control larger than 750cc). Also Water/Alky Injection will be on the car working after 18psi spraying 75/25 alky/water to help running higher boost levels on pump gas.
Turbo: Something between 50trim and GT35R with external wastegate.
Intercooler: Large FMIC with better BOV (didnt decide on which one yet).
Clutch: I didnt decide on which one.
Engine: Motor mounts. Do i need something else here? I was thinking cams and bump up the rev limiter to 7K instead of the low rev limiter of 6K. Do i need head work to handle the extra stress or the stock springs will do just fine?
Exhaust: Electric cutout after a 3inch DP.
Anything else i forgot to list? Feel free to post any pointers u guys see useful. Thanks.
· Registered
a return line system wouldn't hurt
· Registered
I suggest something with 3d mapping ability like our PowerPaq or emanage
750cc OK intank pump is a no go at least with the rest of the stock assembly. We offer a setup that bypasses all of the internal low flowing assembly.
This is always a good idea. We have several setups to do this. I suggest the Aquamist 2c
The GTS61 that we offer is more than up for the task
We can supply you with this as well.
The Spec 3f that we are testing seems to be doing a good job so far.
Oh hell yea and we include them in our kit.
The Crane 14 cams are doing a good job. and there is no reason to up the limiter until you have the cams.
Waste it will cause reversion
Yes you need a return line fuel system. All of what I listed is included in our GTS61 kit (except the waterinjection and cams)
· Registered
FYI $4800 gets you : tubular exhaust manifold, downpipe, GTS61 turbo, silicone charge tube, Turbosmart Veeport BOV, Turbosmart wastegate, Turbosmart MBC, Psi-Fi's new Motormounts, Psi-Fi intake, Psi-Fi intercooler, PowerPaq, Superflow return fuel system, 750cc injectors, and I am sure I am forgetting something. Anyhow it is everything you need to make that power :thumbsup:
· Registered
That is a good deal.... Do u guys have any dyno runs or track times of customers cars with that kit?
1 - 9 of 9 Posts
