1 - 20 of 21 Posts
here's what it does. When I turn the key, all I get is a loud clicking. no fire or codes or anything. all the electrical comes on but not the engine. I need help quick. Car ran just fine about ten minutes ago.
checked it. no change. the fuse is good and ohms out to .2. I think the tone of the click has gotten deeper though.
How can you test that out?
SRTforums Veteran
Can you hear the starter? Can you hear the fuel pump if you turn the key to the last click?
Try having someone mildy bang the starter when you turn it over
Discussion Starter #8
It's not the battery. 12.37 VDC. It's not plugs or wires. where is the stater located? and have then just hit it with a screwdriver?
Discussion Starter #10
all I hear is a loud clicking. kinda like the final buzzer at a basketball game.
voltage means nothing, its amperage u need, 8 AA battery make 12 volts but will they start ur car?
Discussion Starter #12
How many amps do I need? I am not sure how to check it on this multimeter. but it said .001
i dunno - my starter went and made a little clicking. battery does sound like a better possibility
most multimeters dont check amperage, easiest thing to try is, hook the meter up test as voltage, crank the car and watch the voltage drop.
try jumpstarting it. You could have a dead cell in the battery which would make all the electrical things in the car still work, but it wont have enough power to crank the motor.
Discussion Starter #16
Alright, very weird. I went out and tried it and nothing happened. Then I connected the miltimeter between the pos and neg of the battery and it started right up!!! i have no idea why? any suggestions? i'm letting it run for a minute before I try again.
I say dead battery . All u here is ticking noises. Yup its ur battery. Jump start it for like 2 seconds and bamm ,it'll turn on. Trust me bought a new battery at wlamart for 40 bucks with 540 cranking amps and fixed the problem. Had the car over 2 yrs now and first battery.
more than likely a dead cell then, it will randomly happen, just replace it for 40-50 bux.
Discussion Starter #19
Just tried it again, and same thing. No start regularly but as soon as I connect the posts with the mulitimeter, it starts right up!
sounds like a bad cell in the battery
1 - 20 of 21 Posts
