I'm new here to the site!so hope to make friends with everybody.I just
bought a kinetic waste gate actuator and the pcm is throwing a over boost
code i tried adjusting the lenght of the rod from short to long lenght but still
throwing a overboost code.at first when i installed the wastegate i ran the
vacuum line straight from the back of the turbo to the wastegate and it throws the overboost code.then i retried using the vacuum line the way it
was with the stock wastegate still throwing the same code...are there any
other options need some assistance....your help will be appriated...thanks:thumbsup:
Kinetic WGA
Hey,
I bought my Kinetic WGA about a month ago and installed it in about 20 min.
how i set preload was set the adjusting rod on the pin and pull it all the way in (to the right)
then see how far the bracket with the WGA is from the turbo, if you are close then bolt it
up and lock the jam nut should be anywhere from 8-14 Psi. then if you want
a little more shorten the rod. when i get home i'll find a pic to show you. Don't forget to put you clip
back in before starting the car up to test.
More rod less boost
Less rod more boost
What are your mods?You should invest in a Stage 1 or 2 computer and components,that will not only eliminate the code but make the car ALOT faster.
Thanks!!!!
Thanks fellas! i'm going to try what you just wrote to me.if you can if you have time show me the picture of your installment....:clap: :clap: :clap:
