DAN_3KVR4_SRT4 said:
Anybody ever do this on any vehicle? I have the general idea down, and the purpouse to kick out the rear I assume, but what would be the proper technique, and why would you need and want to do this in an AutoX. Thanx fellas.
haha kick out the rear at an auto-x without the parking brake...that shit ain't happening. :lol:
No seriously though heel-toe downshifting is a technique in which, while pressing the brake to slow for a corner, you bilp the throttle with part of your foot in order raise the engine RPM so that it will sync up with the driveline without the engine having to speed up or slow down. Thereby not placing any load on the tires driving the vehicle.
While in a RWD car this is done to prevent oversteer by the engine essentially slowing the rear wheels. A FWD car should do this as well to prevent a sudden understeer condition.
You will want to do this in any auto-x that will require you to downshift back into 1st (or 2nd if the course is big enough) to go into a tight corner.
double clutching is when you literally press the clutch pedal twice to shift either up or down. Most racers, who know what the fuck they are doing, only use this method to downshift.
You see in most true racing cars they don't have synchronizer rings as we do in any modern street car.
In order to downshift without grinding or messing up the tranny they must:
1. press the clutch in to release the car from gear
2. go into nuetral
3. let the clutch out for the input shaft to reengage it to the engine
4. rev the engine to sync up to driveline speed
5. press the clutch back in to disengage the input shaft from the engine
6. downshift to next gear.
complicated eh? this can be done in less than a second with practice.
Infact all this happens under braking so many real circuit racers driving things like a barber dodge or formula ford are double clutch-heeltoe-downshifting.
Although it can get a car into gear a little easier modern street cars (like 60's up or so) don't need to be double clutched.
