1 - 7 of 7 Posts
Ok your talking when your instailing the wires into the wire harnest. This can be done with out a "Hand Drill" just use a electrical Probe or a nail to break the plastic shield. Its really easy, Ive already been through this and its pretty easy just use something to break the seal. The harness is pretty hard to damage so you sould be ok, Good luck.
For reference, you can find the bigger kind, sometimes called a "hurdy-gurdy" at places like Ace Hardware or True Value, along with something called a "push drill.
Also check local hobby stores, small hand drills are used in model making.
Or go with the nail route.
Me, I used a power drill, but I've also freehand drilled a broken head bolt that snapped of 1/2 inch below the block deck with no error:) Tense, but got'er done:)
1 - 7 of 7 Posts
