1 - 12 of 12 Posts
Im going to use this thread to document my tuning. It will show links between map voltage, timing and knock and hopefully give people a good starting point when tuning. Also if you can provide any additional information please do.
Fuel Setup:
RC 750cc
Aeromotive Regulator
Walbro 255
Greddy Emanage/E-01 With LC-1 Wideband
TechGauge Timing/Knock/o2
What started all of this:
I was at the tracking running 20psi, running 13.0 @ 112.6, The mph was pretty low considering the turbo.
Data for this run:
Knock Retard: 8 Degrees
Map Voltage: ~3.65v @ WOT
AIR FUEL: 10.X falling to 9.X
BOOST: 20psi
Fuel Pressure: 43psi base
In an attempt to lean out the 10:1 afr, more fuel was pulled via the emanage resulting in:
Knock Retard: 11 Degrees
Map Voltage: ~3.5v @ WOT
AIR FUEL: 11.0 falling to 10.x falling to 9.x
BOOST: 20psi
Once i got home from the track, I had a feeling my knock sensor may be messed up, so i zero'ed out my emanage and ran only a 4.0v clamp
Knock Retard: 0-1 Degrees
Map Voltage: ~4v @ WOT
AIR FUEL: 10.x falling to 9.x
BOOST: 20psi
What i see from this is that i need to lower my fuel pressure to lean the car out at this point, pulling any significant more amount of fuel through using map voltage will cause spark knock. I will be trying this at the track tomorrow. Thoughts? :hi:
this is just a thought and a problem i had, the injectors are too big for the boost you are running. i was using s2 injectors with the stock turbo and just seemed i could not pull enough fuel even at 22lbs. this was with w/i as well though. i went back to the s1 injectors and tuning became SOOO much easier. now i can maintain a steady 12:1 a/f across the board. I also have 0 knock and map is clamped at about 4.6 volts..this was monitored on an lm-1 and chrysler drbIII
I also had this same issue with s2 injectors on the stock turbo, unable to pull out the fuel without advancing timing too much.
yeap, exactly, i would have to clamp so much the timing would be f'd all up. and i was still seeing 10.8:1 at redline and loosing too much hp. I've yet to jump back on the dyno, but datalogin shows much better results on the road. Last time i dynoed w/ the s2's i put down what is in my sig, and that was with a 12.5:1 a/f dropping off to the 10.8, now with a steady 12:1 i should have picked up a few ponies. why not try some different injectors? Still got the s2's kicking around?
im going to try lowering my fuel pressure and see how that goes, nope the stage 2's were sold once I got the big turbo.
good plan, but if you see yourself going to low with pressure, keep the smaller injectors in mind. what pcm are you using? stock, s1, etc.?
distinctdev...
How is your fuel pressure setup? Are you running a static system? If not where is your vacuum line running from?
Discussion Starter #10
WhatsADSM said:
distinctdev...
Vacuum line is from the red line (boost only), and its a rising rate 1:1 regulator. What pressure are you running with you vacuum line off?
Check your PMS.
Although your setup isnt bad (the boost only source is a good one BTW). Im surpised that with all your mods and basically a 4.0v clamp you are in the low 10s for AF..
You also have exhuast, FMIC, etc? correct?
Discussion Starter #12
WhatsADSM said:
Check your PMS.
Yes: agp fmic, needwings dump.
Ill let you know how things go with your advice. Im gonna check my plugs and wires also.
1 - 12 of 12 Posts
