Is there any reason why my check engine light is on? Yesterday I had the profec b spec 2 installed with the agp wga already on the car. I took it to a turbo shop and had them tune the ebc. after an hour of driving the car my check engine light came on and then everytime I'd hit max boost in my low and high boost settings the warning sign came on. Does anybody know what could be wrong?
Discussion Starter · #2 ·
bump. PLEASE SOMEBODY HELP ME.
are you overboosting w/ stage 0? that could cause a code..Which code is it? As for the ebcs warning, it might not be set high enough...If you didnt set the profec yourself, they might not have set it enough. I can have one set level of boost and be fine w. my warning, but if the temp changes It might boost just a bit more causing it to turn red.
check your codes, maybe p1188 code. cycle yor key on and off 3 times and look at your odometer, should show your code.
