i added springs and a blow off valve its doing so good so far the bov sounds great. just wondering what i should do next for horsepower that is safe and do they have a harness for the greddy turbo timer for our cars? and what pounds of boost should these cars run stock?
You will see different boost levels in different gears (Lower in 1st and 2nd), and in different weather conditions.
I peak out stock at about 13 in 3rd through 5th gears. There is a little bit of fluctuation on the stock boost guage, so exact numbers will require a better quality guage.
You will also find the boost to be lower until engine reaches normal operating temps.
Hope this helps.
thanks man cause when i added the hks bov i wanted to make sure im not leaking im getting 13-14 psi right now thanks.. do you know if there is a harness for the greddy turbo timer??
exhaust depot makes a modified harness for the Greddy turbo timer. I ordered one, but it hasn't arrived yet. http://www.exhaustdepot.net/srt4.html
