TechGauge readings
SRT-4_UK said:
Kr should be as close to 0 as possible and BTDC should be in the high 20s max at WOT.
I generally agree with SRT-4_UK but.... there are some exceptions.
To maximize power, MOPAR has generally "allowed" several degrees of Knock Retard.
Typically -- even on Water/Meth injected cars -- 4-6 degrees of Knock Retard Timing "pull" can be seen.
This is a function of MANY variables:
Altitude [ i.e. Air Density ]
Ambient Temperature [ Hotter = More tendancy to Knock ]
Inlet Air Temperature [ Larger FMIC DOES help ! ]
Fuel Grade
And on and on.
If you can keep your KR BELOW 4-6 Degrees of timing being "pulled" this is generally a Safe and desirable condition.
Total timing at WOT can be in the High 20 BTDC [ Before Top Dead Center ] IF you can lower Intake temps with either or BOTH larger FMIC/ Water Meth injection.
The idea is to set a baseline by using GOOD :hi: instrumentation and then observe changes as you modify your engine.
Hope this information is useful !
Best Regards,
Bob Weiland
TechGauges
For instance, on my car this morning with AIT's of about 85 (nice cool morning), I was getting up to 6 degrees of retard in 2nd gear, but 3rd only hit 2. Weird, but that's what you get for owning a Neon. ;)
I just love the fact that I can actually see it. :)
