Not sure what the question is here, but let's think about it this way...if you're running 750s in your car obviously it would be way too much fuel at 58psi when idling, so you bump the fuel pressure down at idle. Still you're not dropping them low enough with the fpr at 43psi to give less fuel than stage 1 injectors and maybe not even low enough to give less fuel than stage 2 injectors. So really you're only bumping the fuel pressure down at idle to make the car run correctly, not to save gas mileage. If you want to save gas, you'd better take that big turbo off and run your stock injectors mang. Atleast thats what I get out of it
