Fuel injectors.
504 Views 4 Replies 5 Participants Last post by  SRTie4k
What is the cc rating on a 2004 srt-4 stock injectors?:hi:
577ccs
577cc/min at 58psi(good for up to 335hp)
but only
500cc/min at the usual 44psi most aftermarket injectors are rated at.
for referrence s2 injectors (good for up to 400hp):
682cc/min at 58psi
590 cc/min at 44psi
digging up an old post, but at least I searched
so would a set of aftermarket 590cc's be a direct replacement?
As long as that rating is derived from a 58psi test environment, you should be fine. 90% of injectors are rated at 43.5 psi, however. You might want to double check.
