please sticky this.
i hold no responsibility if you are an asshat and you dick up your car. :clap: do one door at a time in case you need a reference.
bigger pics are located here: http://www.niceguyracing.com/gallery/thumbnails.php?album=50
1. disconnect negative terminal of battery.
SPEAKERS/MIDS
2. using a phillips screw driver, remove the 3 screws in the door panel. one below the sail panel, one in the handle, and one in the cup.
3. gently, but firmly wedge up and pull out the switch panel. there are 3 tabs.
4. on the electrical connector for the mirror, slide the red tab out. disconnect connector. pull straight out hard, but don't break it. they are in there really tight. disconnect the other two connectors also [window switches]. they have the tab you have you push in while pulling. you have to remove the black connector first.
5. to remove the rods that connect to the handle, you need to rotate them. it's difficult to explain. they will pop off, then pull the rod out. be very carefull not to break them. but like before, they take some effort to remove.
6. once those are disconnected, disconnect the electrical plug for the door locks.
7. using a wide flathead screw driver [or your fingers] very carfully pull straight out on the door panels sail panel. there is one tab holding it in place.
8. starting at the above sail panel, work your way clockwise, pulling the panel apart. there are 8 pop tab things. pull firmly. remove door panel by pulling up and out. set aside face up so you don't scratch it.
9. unscrew the 3 screws holding the stock speaker in place.
10. use a flathead screwdriver to wedge the speaker out. it is held in my some stick tape stuff. just get a finger in there and pull. be carefull not to pull too hard and break anything.
11. disconnect the speakers electrical connection. push in the tab, pull out.
12. my speakers came with adapter rings. i simply lined them up, drilled small holes in the stock rubber, and screwed the adapter ring in place. if you don't have these, you will probably have to take the stock speaker apart to retrieve the gold colored ring with 3 tabs and screw holes, and drill 4 holes in that and mount you speakers to that. [i believe petar did that. maybe he's got a pic??]
13. if you got adapter harnesses, like from crutchfield, then skip this step. cut the connector off the harness. leave about an inch of wire on the connector just in case you ever need it. toss the connector away. unwrap the tape. pull apart the wires. you should have one green wire, and one red [or brown.. can't remember]
SPEAKERS/MIDS
