Hey All,
I'm installing a AFR Gage in my car and doing some wiring thru the firewall and saw the following that will certainly over time be a wiring problem.
The Clutch Lever when fully depressed will mash the Brake Switch wiring harness against the floor board. Mine is crushed, but still functional. There are 2 push pins holding it exactly in place for this to happen! I'm going to try and re-route mine as soon as I can get the plug out of the Brake Switch. I had no luck so far in getting out the plug but will try again later.
Look at yours now to see it for yourself. Mopar and you need to know about this.
