1 - 2 of 2 Posts
im trying to figure out if my vac lines are hooked up. when refering to the wg as a "can" like most do. is the "top" nipple the one by the dump pipe, or is the nipple by the dump pipe the "bottom" nipple?
right now i have a vac line from the compressor housing attached to the nipple on the side closest to the dump tube. is this correct or am i backwards?
might as well ask about my bc also.
com port is t'ed into the line from the compressor and nc port is attached not the nipple furthest away from where the dump tube bolts up. Correct?
Discussion Starter · #2 ·
i know one of you turbo gurus know this.
1 - 2 of 2 Posts
