1 - 9 of 9 Posts
Does anyone know why my boost is variyng from 15-17 at WOT,...i never noticed this before yesterday, i'll be at full throttle in the upper gears & the gauge slowly goes up & down, Up & down, between 15 & 17 lbs.??........the only mod i have is Stage #1............any suggestion's?....i checked all my clamps for tightness already.& found nothing?, it seems to run fine otherwise._________5TOEZ_________
mine goes 15-17 bone stock. then it drops down at redline
Normal, don't worry about it. You should be looking at the road and not the boost gauge :)
First off... pdieppa is right. Becarefull man, that'll get you easily into a bad accident.
Mine is stage 0 with Mopar BOV and it does it but between 12 and 14. I don't know what it could be but the car runs fine. I'm gonna check the clamps today.
Your not supposed to be boost 17lb's on just stage 1.
You probably have a leak in one of the lines.
I wouldn't be surprised if it's the green nipple that comes off the turbo.
Mine had a little hole in it.
thanks guyz.........
I'll be sure to check my green nipples & keep my eyez on da road too!_____________5TOEZ____________
from my experience...check/replace plugs and plug wires
the reason your boost is varying is because you have the stock wga. Get a new wga and a boost controller and your car will boost and hold to certain psi's.
1 - 9 of 9 Posts
