I wanna put these wheels on my car there Flik Wasp 18X7.5 ET:33
what do i have to do to put these wheels on my car ? i wanna put NITTO's NT 555 225/40ZR-18 92W
Administrator
you need to remove your old wheels, remove the crush washers, install hub rings into new wheels, push wheels onto lug studs, use supplied "tuner" lugs to bolt wheel to car, torque to 90-100 ft/lb using a torque wrench.
if you did not get hub rings or lugs with the wheels then you need to measure/find out the hub bore on the wheels and call up discount tire direct and order some xxxx to 57.1mm hub rings. You can also get the lugs from them.
good luck with the tires. :)
the only thing i was worried about was the 33 mm offset
Administrator
it will stick out a little bit compared to a 40mm offset, but shouldn't hit the fender unless you are slammed.
