1 - 7 of 7 Posts
i was just wondering, i'm thinking about modifying my boost set up,
like you know on S0 the boost doesn't rise much in first, is it better this way
or could i up the pressure in first gear too. from what i have seen with second gear...traction will be a probleme with boost in first gear for sure
ok motor mount would help. :hi:
No traction in first :( Even from a rolling start going easy on the throttle then WOT - as soon as your turbo wakes up... RRRRRIIIIIIIIPPPPPPP the tires break loose then slam second gear, etc...
I actually try launching around 1800 with a slip of the clutch and 3/4 throttle giving it a little more until around 4700 rpm when they break loose for me.
Stage Zero for me and my current setup includes a shorty antenna - good for 500 whp i hear. Well... that's what i hear. Otherwise i'm pretty much no power adders.
- Ninja
Discussion Starter #6
I should try a normal srt, i got acr and from feeling my tire wont break loose in firt unless i get dirty,..
1 - 7 of 7 Posts
