321 - 340 of 349 Posts
If you change your mind on the rods lmk, I've got a bnib set of pauter rods.
Discussion Starter #322
Just have a power goal of around 530-550 what ever it makes again on 28psi but max psi 30 with the crower cams i dont need any more power then that right now all the labor is done myself so labor is free
Bed plates crack @500hp, so get a strap kit.
You put it back together yet? Or did you unload it for a trans am?
Discussion Starter #329
Forgot to update thread motor is back together had machine shop check out block and make sure clearances were good so i purchased std wisecos pistons and got the stock rods re sized for the arp rod bolts. Car fired up sounded beautiful but started smoke and removed turbo and loads of shaft play. Precision has the turbo waiting on phone call then can drive it havent even put 1 mile on motor yet :/ ..o and kept the stock cams didnt have a budget for cams as my boy is due next month.
Thanks hybridkid! Whats up long time no see! Hows the blue car? Coming to showdown this year?
Yes, I plan to be there. Just waiting on the turbo to get back from TurboBay so I can finish putting things together. Should have Blue running by middle of Sept.Xfingers
