1 - 19 of 19 Posts
finally on my 7th try on slicks i managed a decent pass. (best so far is 12.0) up til now its bin bogged out launches and missed gears :ninja: :flame: finally after a 6k off the limiter launch technique. ( for some reason every other way it bogs out and cuts a 2.0) i managed to get off with 1.805! 60ft :clap: :clap:
mods.
psifi cai
psifi gts 58 turbo kit
22psi in 1-2 gears and 29 in 3-5
116oct
3inch turboback with out cat
psifi 2nd gen ic
lfs tb
psifi piggy back, untuned with 11.0 and richer a/f ratio. (hence the low trap)
new plugs, wires, psifi motormounts/ tranny mount
stage 4 cm 6puk clutch
rc750s, with returnline/ regulator kit
225 fuel pump.
crane 14s set at 0
m&h 24.5X8.5X15 slicks on k1s with 13psi of air
skinnies in the rear on 4inch bogart wheels
lca bushings
revitup traction bars
slip
.237
1.805
4.966
7.502
96.05
9.718
11.580
121.57
Good job guess that moves me to like 35 on the list now lol.....keep it up
hell yeah nice run man. Trap should be higher though, lean it out a bit like you said!
Also, it looks like you may not need that nitrous kit from l0c0, you want to hook me up??? :crying:
makes me #14 wooo!!
Discussion Starter #6
update when out last night on just street tires trying to better my self again. last time was [email protected] this time it was a [email protected] with 2.2 60ft. i can't get 2nd not to spin for the life of me, even short shifting easy, laying any power in 2nd at all it spins, owell...
Discussion Starter #8
thank ya much. i was so surprised for the good time. it was one of those runs u know its the one. i new it was 11s but not a freakin 11.50
nice 1/4 trap too
great run! where did you pick up the skinnies? any pics?
Discussion Starter #12
no pics of the skinnies yet. i picked them up from silverscooby. never used. there bogart wheels with 26X4.5X15 mt skinnies.
i have the slip at home but my scanner doesn't work with xp64bit. i tryed to take a picture of teh slip with a didgcam but it can't focus on something that small and grainy. raced at cecil county dragway in maryland.
just curious have you ever dynoed the car because on 28-29psi i trapped 96mph in the 1/8 and went all the way to 126 up top
Discussion Starter #16
on 22psi strait pump gas it was 396/398. the car is so rich is doesnt even show up on the widebandat the dyno. even with c16 and 29psi. on my aem incar wideband it still doesn't come on gauge which goes 11.0 at the richest. thats why the low top end. here is the dyno chart.
mods.
psifi cai
116oct
psifi 2nd gen ic
lfs tb
225 fuel pump.
crane 14s set at 0
lca bushings
slip
.237
1.805
4.966
7.502
96.05
9.718
11.580
121.57
A Big CONGRATS.:thumbsup:
www.mandhtires.com
John
M&H
Discussion Starter #19
whats really weird is i can run the same lowered 1-2 gear boost (17psi) on the street then take the same to the track and i can't hook up. strange. i can floor 1st then wot shift into 2nd on the street and spin yes but it does hook up. at the track even if i short shift and slowly get back into the gas it still spins. i think my next tire will be a 245 bfg dr. will suck in the turns but owell.
1 - 19 of 19 Posts
