I am posting here because i am wondering what everyone thinks about my plans. I am saving right now for these following mods.
AGP turbo kit with 60 trim, B+B turbo back, a 3 inch cold air(not sure wchich one yet), hard pipe kit with RFL BOV, 650injectors, wideband o2, power pack, turbo xs 2 stage mbc, and intercooler sprayer not sure if im going nitrous sprayer or just a water sprayer, but im thinking if i properly tune it and have good AF ratios, at 20lbs around 380-400Hp, just wondering what you think, and if there is anything else i should get or anything i should get rid of, also what kind of #'s should i expect and estimated 1/4 times, mind you i am a good driver so the best you think the car would do. thanks
380+ horsepower, low 12's, very high 11's, If you can get traction and a perfect launch. You will probably have to have the intercooler piping fabricated with the turbo change though, won't you?
im not sure, i thought that the stock exhaust placement and the AGP were about the same, concidering you can use the aftermarket intakes with the AGP kit, i may be wrong, if i am then i may have to invest in some custom pipes.
