i had nothing better to do on saturday. so i take everything apart on my ic sprayer cuz i suspect i have a bad check valve. so while everything was apart i decided to tighten all the pipes just in case. i noticed that the one on the hot side of the ic was a lil loose(i could pull the rubber lip up with my finger) so i tightened it. also the hose on the back side of the turbo was also slightly loose. i tightened it also. last but not least i tightened the mopar blow off valve.(it was already tight i just tightened it more about half a turn on all bolts) of course i reset the computer, and started her up for a test drive.
here's what i noticed:
my dab set at 0 i gained from 5-7psi max to 8-10psimax.
my partial throttle response is crazy i spike to 14-15psi in just second gear. i squeel my tires at partial throttle in 2nd gear, and these are new tires.
the main difference is that my partial throttle boost is real touchy i tap the pedal and it jumps so quick its scary. my boost gauge seems to be less shaky also it holds 17psi (without bouncing) til 5500-5600 then it slowly tapers away.
also i put zip ties on the green and black hose(wastegate and the turbo) i noticed that the lightweight stage 3 car had a zip tie on the wastegate hose. so i zip tied everything.
if i had a boost leak then man it must have bad. i never heard it or anything but i believed it was there. whoever tightened the hoses must have been told not to tightened them all the way or something. because they were loose.
everyone who owns a srt-4 i would recommend checking those hoses.....now:hi:
