1 - 10 of 10 Posts
Engine light came on under normal driving. I dont tihnk it is the CAI cuz ive had that on for about 3 days, so i would assume if i installed it or did something wrong i would have found out 3 days ago.
Do you think the dealer can throw out my warranty if i bring it in with a diff intake?
good advice, thanks
zr8td2k said:
make sure your gas cap is tight. I just had 2 friends go through the same thing and their caps were loose.Sounds dumb..but hey..how hard is it to check.
haha no i did double check that. And made sure the oil cap was still on.
Discussion Starter · #9 ·
found out it was my WGA huose popped off. Put it back on but the engine light stayed on. Dis/Re- connected the battery and light was still there.
Took it 2 the dealership and it was the WGA reading overboost. Problem solved, warranty still active.
They can only not honor warranty if they can prove that the mod caused the damage.
1 - 10 of 10 Posts
