Someone has to have an answer or suggestion.
Sp3kter said:bad ground could be the problem. What brand boost gauge?
Panzer said:It's a autometer 30psi. I have my other gauges going to the same ground and they work fine. I might have a boost leak, yesterday was the first time I started it after sitting since September. Say I check and I have no boost leaks is there anything that it could be?
If the gauge is faulty what can I do about it? This guage wasn't cheap, am I going to have to eat it and buy a new one or does autometer have good customer service and exchange policy. I installed this gauge yesterday and drove maybe 10 miles with my car so it's still brand new or pretty damn close to it.eviilboy said:Panzer said:It's a autometer 30psi. I have my other gauges going to the same ground and they work fine. I might have a boost leak, yesterday was the first time I started it after sitting since September. Say I check and I have no boost leaks is there anything that it could be?
hard to believe.... but possibly a faulty gauge.
Panzer said:If the gauge is faulty what can I do about it? This guage wasn't cheap, am I going to have to eat it and buy a new one or does autometer have good customer service and exchange policy. I installed this gauge yesterday and drove maybe 10 miles with my car so it's still brand new or pretty damn close to it.eviilboy said:Panzer said:It's a autometer 30psi. I have my other gauges going to the same ground and they work fine. I might have a boost leak, yesterday was the first time I started it after sitting since September. Say I check and I have no boost leaks is there anything that it could be?
Go to the autometer web site. They have a contact section, so here is the link:Panzer said:I hooked up my stock boost gauge to the vac I'm using for my new one but I did it in the engine bay. The stock read perfect vacuum . My electronic was still reading between -5 and -8 bouncing back and the vacuum line wasn't even hooked up and when I shut the car off the elctronic went back to 0.
i was just gonna say the exact same thingthepowertowin said:I just fixed this exact same problem on mine. You're probably hooked to a keyec ignition feed that does not keep voltage while cranking.
So it is resetting the gauge during cranking. You must use a 12 source that is not interrupted during cranking.
What's a good wire to hook up to? I think I have mine hooked up to the black wire with white strip behind the fuse panel inside the car.thepowertowin said:I just fixed this exact same problem on mine. You're probably hooked to a keyec ignition feed that does not keep voltage while cranking.
ThanksSp3kter said:thin blue wire will work
