1 - 7 of 7 Posts
did somebody tried to put a ebc, greddy turbosmart or what ever, on th stock solenoide...just for the look and simpleness of it
and if you unplug the stock solenoid do you have a cell ??
the solenoid that the pcm use to drive the WG, number two i think,
thw one closest to the battery, with the green and black line
it will work but the ebc will go nuts trying to keep the psi constant since the stock solenoid will be bleeding boost signal on & off. when i tried an mbc on the black line once i got nothing but flutter..
not sure about your answer..??
what i mean is use the EBC signal to the stock solenoid, so that should work exactly like the solenoid coming with the EBC,
in a sence the stock one could work on it.....but if you cut the lines and used just the stocker you will get a cel.....i am currently not running and of the stock solenoids but i have stage 1 also and tip is plugged...but all the electircal connections must still be hooked up or it will throw a cel....the stage 1 does read the solenoids but it just ignores them.....so down to the point yes it could work but you would have to wire up a diffrent one and still leave the stocker only hooked up to the electric part
Discussion Starter #7
that's what i tought...that's why i have an extra set of solenoid... :lol: nah i just have them, for other project :rofl:
1 - 7 of 7 Posts
