Can I use an Electronic Boost controller(EBC) with my stage 2 wga without problems, or should I get an agp wga.
I am using the Greddy e-01 to control boost on my Stage 2 without Toys. Because I live in a cool climate, The Stage 2 PCM would not allow me to boost over 15psi. As a result, I wanted to take over control of how much to boost. With the Greddy e-01, you will need the AGP WGA. The e-01 does not work with the Stage 2 WGA. Chad (SY04SRT4) did the install and tuning on my car. The e-01 is set to run three boost settings--(OFF) position which is just the AGP WGA spring pressure of 12psi, (LO) is around 16psi, and (HI) which is between 18 and 19psi.
An electronic boost controller works with Stage 2. However, you will need the AGP WGA.
