1 - 2 of 2 Posts
As the title states, what is the target afr on e50? Is it the same as e85 (12.0-12.5)?
depends on what you are doing. if youre looking at a AFR meter ignore what ever fuel you have in the tank. just use the old school AFR figures for gasoline. Because your meter is calibrated to display lambda converted to gasoline afr.
on the other hand, if you are tuning and are setting the stoich AFR in the software then you need to figure out what that number should be.
gas 14.7
E50 12
E85 9.7
1 - 2 of 2 Posts
