I took the car to dyno today. I did not do a stock run on the car. I have seen most guys put down 220 to the wheels.
The first run was done with no cool down of the car or no fans. I drove in, strapped it on and ran it.
First run was 219
Second run we let the car cool down and we used the fans.
228
third run we cranked the boost to 15psi. It dropped down to 13 psi after a few which is why you see the huge increase in TQ but a lower HP.
Fuel was at 11/1. If we can get it to about 12/1 it will run alot stronger. Did some one say AFC?
So it looks like the exhaust gave a good 8hp to the wheels which is not to bad. NExt mod is the intake
The wastegate was shimmed open a little which I know made me loose some performance. It took me some time to figure out how to set the HKS EVC5 correctly. It has extra vaccum hoses to it. One goes directly to the intake manifold to get a good manifold pressure reading. The problem is taht there are not to many nipples to tap of from. You want a nice dedicated nipple so the signal wont be affected by the BOV etc. I now have it set up correctly and im getting no more fluctuation on teh wastgate. If you get a EBC, get teh profect b, its easier to install.
First run was 219
228
