I recieved my TCS traction unit and had to proceed to get it in, followed instructions, everything went pretty smooth, took around 3 hours now when i start my car it just dumps fuel, reads 15.0 at first then slowly drops down to 10.0 and then goes to around 11.5 and stays. When i installed the TCS i had to wire into the ignition coil and into the BLACK PCM plug, i also have some wiring from my DTEC, i actually have wiring everywhere and im guessing, something is either shorting out or something is disconnected. Question is, which wire, if one did some unhooked would cause the car to dump fuel? I was thinking MAP sensor but i wasnt even near that wire, but i also have wiring running through that grommet for the DTEC and everything else including the TCS...
when all my stuff got installed my car was dumping tons of fuel and it was due to a loose connection on the TPS plug....check that out
