1 - 3 of 3 Posts
when im at idle the dtec says im at like 10% on the tps and when i shut the car off it goes even higher wtf is the deal? i set it at 3500mv because im stg2 do i need to use the auto calibrate or is it a tps problem possibly? i soldered all my conections and should be good on that my throttle was being funny a little while ago but went away i noticed today also when i closed thottle decel it stays in the 13-14 range on my wideband but idle is perfect wtf is the deal any input would be appreciated:thumbsup:
ok so ive researched this some more and it seems to be normal now my only question is i did a few pulls and data logged them and i never see 100% tps is that normal?? im considering wiring to the tps instead of the map any sugestions?
yes mine says 10-16ish at idle them like 40-50 when car is off what causes this?? also i contribute the funny idle to resetting ecu and i have a big throttle body any other opinions? is this normal? i do auto calibrate it reads 0
1 - 3 of 3 Posts
